It is currently June 14th, 2025, 9:41 am
PostPosted: February 29th, 2016, 6:27 am
Futurist full screen widget with cool appearance and functionality.
Icons used: Senary Icons by Arrioch
**2 VERSIONS**
v1: Mouse over each wall-shortcut to pop-up the icon from the center panel.
- Click on the screen (photo album) to go to the next picture
- Support for drag-drop for the shortcuts
v1: Mouse over each wall-shortcut to pop-up the corrisponding shortcut name from the center panel.
- Photo album settings
- Open folder
- View photo
- Refresh files
- Shortcut settings (on each shortcut)
---FITS ON 1366x768 RESOLUTION---
NOTE:
Use the "Virtual Widgets" to combine them with the widget.
viewtopic.php?f=11&t=6201
Virtual Desktop.rar [10.59 MiB]
Downloaded 312 times
