It is currently October 23rd, 2026, 10:33 am
 Post subject: Embossed Widgets
PostPosted: February 8th, 2016, 6:50 pm
5 widgets in embossed cool style.
* 3 Digital clocks: v1, v2 center, v2 corner
* 2 Weather widgets: Horizontal, vertical
Right click for the various options
NOTE:
I tried to use a script for the temperature to hide the zero-first digit (for temp <10°), but there was a bug with the alignment of the digits when the location/temp changed. Same issue with the "-" symbol (for temp <0°). So the widget unfortunately will not show properly the negative temperatures.
Embossed Widgets.zip [1.91 MiB]
Downloaded 367 times
Users browsing this forum: Google [Bot] and 166 guests
