It is currently October 23rd, 2026, 10:33 am
PostPosted: February 8th, 2016, 3:33 am
Display's CPU, RAM, Bin, Network, IP, Date and Time.
And, Local Weather, CPU Name, United Federation Of Planets header, and Memopad.
Clocked CPU usage at 6.73% - Runs higher (23.9%) when all panels are closed, that's weird.
File comment: Starfleet Command Meters v 1.1 Screenshot
Starfleet_Command_Meters_v 1.1.xwp [1.93 MiB]
Downloaded 361 times
AST_GMS
"Expressing Ingenuity"
My Blog-https://amerispheresoftware.wordpress.com
PostPosted: February 9th, 2016, 1:12 am
Excellent, thanks.
PostPosted: February 11th, 2016, 7:55 am
Ur Welcome.
So, I switch my OS from Win 7 to Win 10 Pro x64, installed XWidget and it works. Ran this widget and CPU usage was as I stated above, and after running for about an hour, the CPU usage jumped up to an average of 30% to 49%. I haven't been able to narrow down the true cause -but- I'm able to go so far as to say, "This behavior is indicative to outgoing unwanted traffic being sent to a remote location." I surely hope that this isn't the case. And another weird thing -is- when offline the accuweather core display's San Jose, CA as the weather location, even if its not set in the location settings. I'm sure this is caused by the code written in the core itself -but- I just want it to be noted, this default location should be taken out of the core code cause it raise's suspicions.
Thanks,
AST_GMS
Users browsing this forum: Google [Bot] and 166 guests
