It is currently June 14th, 2025, 8:33 pm
PostPosted: January 27th, 2016, 3:19 pm
Ok, I'm sharing my first created widget. I never was a fan of forums due to the fact they are difficult to navigate. Anyway, if you the Admin can be so kind to tell me how to upload my widget to the XWidgets Gallery It would be greatly appreciated. :D And, if you take the steps to upload my widget to the gallery, I'd like to be informed that it is now at the gallery, thank you. I thank you for your free software, its awesome and not heavy on resources like Rainmeter, which I have created many rainmeter skins. Thank you,
This widget currently has a slide out panel.
File comment: My First Created XWidget
AST_Starfleet_Folder_Launcher.xwp [623.99 KiB]
Downloaded 306 times
AST_GMS
"Expressing Ingenuity"
My Blog-https://amerispheresoftware.wordpress.com
PostPosted: January 27th, 2016, 3:29 pm
Thanks for sharing.
Please include a screenshot of your widget.
The uploading system is "limited". Only the staff member can upload widgets to the official gallery and this happens though a chinese server. So you can't do it by yourself. Just post your widget/s here. Don't worry because who use XWidget knows that there is also this forum and the XWidget section on DeviantArt. The gallery it's only a part of all the widgets available.
PostPosted: January 28th, 2016, 7:37 pm
Ok, great. Thanks again jimking - :) I'll be creating a new page at my site for all the widgets I create (currently working on two) and they will be available for the world to download. And, I'll be writing a post at my site about XWidget and its wonderful use. Oh, I've found some bugs and mis-spelling's in the XWDesigner.exe. Posting them will come in the coming days, and will be placed in the right thread.
AST_GMS
PostPosted: January 29th, 2016, 2:23 am
The Dev works already for the v2.0. Please post any bug that you have noticed in the right section.
Thanks for sharing and welcome to XWidget community :)
PostPosted: January 29th, 2016, 4:19 am
Hi jimking, "The Dev works already for the v2.0.?" What does that mean? If its suppose to mean, XWidget.exe v2.0 is the release I downloaded the other day from the XWidgets web site its not v2.0. The about window says its, version 1.9.3.1022. Anyway, your statement is a bit confusing. :? From what I'm reading it has nothing to do with my previous reply. Thanks. :)
AST_GMS
PostPosted: January 29th, 2016, 6:53 am
Yes the v1.9.3.1022 is the latest one! :)
Since you noticed some bugs in the designer, I told you that the v2.0 is one the way. So I mean that possibly these bugs will be fixed.
More info here
viewtopic.php?f=2&t=4098
pm: I checked your widget. The sounds are cool!
Suggestions:
1) I think you should add the possibility to edit each shortcut (with the right click option)
2) Add show/hide text-name for each shortcut in the middle below it will make the widget more functional.
Example
http://jimking.deviantart.com/art/Cyan- ... -510895121
3) You can use a "star trek" style font to give more cool look
PostPosted: January 29th, 2016, 7:35 am
Oh OK, can't wait to see v2.0. I'll take your suggestions under advisement, they sound logical. :) And the text "United Federation Of Planets" is a star trek font (Starfleet Bold). Thanks.
AST_GMS
PostPosted: January 29th, 2016, 8:07 am
You can use it for the date/time then ;)
PostPosted: January 29th, 2016, 8:49 am
Yes your right, I thought I set it that way too. But, because I'm working on two other widgets, It'll have to wait.
AST_Starfleet_Folder_Launcher v2.0 it will be.
Thanks, - :)
AST_GMS
Users browsing this forum: Google [Bot] and 39 guests
