It is currently June 14th, 2025, 8:21 pm
PostPosted: January 14th, 2016, 9:08 am
Second concept weather widget of the upcoming Samsung Galaxy S7.
galaxy_s7_widget_concept_2.xwp [4.51 MiB]
Downloaded 252 times
PostPosted: January 15th, 2016, 5:26 am
Very nice. I installed on my Galaxy S5 and made a few modifications (added hi/low temp, conditions, and removed leading zero in hour). Thanks!
PostPosted: January 17th, 2016, 2:24 am
Nice. But you manually created the num 10,11 and 12 for the hours? If not, the time will not work properly.. :!:
PostPosted: January 17th, 2016, 10:52 am
No, I created a separate "hourstens" folder with the "1" image and a blank one for the "0" image. I did the same with the S6 widgets. Works like a charm.
PostPosted: January 17th, 2016, 11:29 am
I see! Good ;)
The "bad" is only the position of the numbers that are not on the left part..
Users browsing this forum: Google [Bot] and 37 guests
