It is currently June 15th, 2025, 6:20 am
 Post subject: Air Balloon Shortcut 2
PostPosted: June 9th, 2015, 2:46 am
AirBalloon flight around your desktop - Click to open shortcut (on the lower part)
This the 2nd version of my old "AirBalloon Shortcut" widget, now with 11 different types of balloons! :D
Right click:
- Allow flight ON/OFF
- Edit / change shortcut (or drag your file)
- Create New Widget (to add directly more balloons)
- Choose type
****NOTE****
If you want to turn on the "Swim Keep on Screen" (the balloon will stay on screen/between edges of the screen) :
Right click on the widget -> EDITFrom the "Window Type" menu on the right CHECK the "Swim Keep on Screen" option.
air_balloon_shortcut_2.xwp [1.77 MiB]
Downloaded 240 times
Users browsing this forum: Bing [Bot] and 41 guests
