It is currently June 15th, 2025, 6:23 am
 Post subject: ZTE Blade 3 v2
PostPosted: June 2nd, 2015, 10:21 am
Alternative version of the "ZTE Blade 3" widget.
* The top image changes between day and night.
zte_blade_3_v2.xwp [5.8 MiB]
Downloaded 364 times
 Post subject: Re: ZTE Blade 3 v2
PostPosted: June 2nd, 2015, 1:32 pm
I have a problem with this one (phone widget). It seems to have a problem to send this widget to phone, takes so much time (lost usb connection and come back) and when it happened (after 3-4 attempts), there is no upper blue background (day or night) just transparent one and it looks same as ZTE Blade 3. On PC everything looks fine as well as other widgets.
Also on Accuweather S Widget v3, city name is messed up with weather info (words), and minute digits are very close (next to) two dots separator. I tried to resize it on the phone, but everything is same. Also this one works fine on PC.
My phone is LG G2.
PostPosted: June 2nd, 2015, 1:49 pm
milicevic... I have to tell you that ALL the widgets that I post here work properly ONLY on PC!
I make extra adjustments ONLY before post them in the app's gallery!
PostPosted: June 2nd, 2015, 1:52 pm
Ok thanks. I saw that all of them are windows version and they worked just fine on android, except these two. That's what confused me.
PostPosted: June 2nd, 2015, 2:14 pm
Most of the widgets need some mini-adjustments. Especially when a widget uses java script that is not supported on Android.
The resolutions are different so it's logical. Some of them are ok.. I notice that the problem exists only with the texts and depends a lot on the alignment that you use in the Designer.. But not always happens.
Anyway, I will post of these last widgets in the app's gallery as soon as possible!
Users browsing this forum: Bing [Bot] and 40 guests
