It is currently June 15th, 2025, 6:23 am
 Post subject: Accuweather S Widget v3
PostPosted: June 2nd, 2015, 10:09 am
Original design By "smoky-jr" from XDA.
http://forum.xda-developers.com/galaxy- ... d-t2712475
Update Weather (or use the button)
accuweather_s_widget_v3.xwp [9.72 MiB]
Downloaded 218 times
PostPosted: June 7th, 2015, 12:11 am
Unnecessary icon.
Few images of weather.
The storm, there is no lightning
Rain, little drops
Snow, little snow
I do not understand wtf1 folder - empty picture cloudy, fog empty picture ....
Besides, it is very nice.
PostPosted: June 7th, 2015, 1:24 am
Hey man. Sorry but where are all these!? :shock:
The widget combines 4 different ways to show the weather conditions and I garantee that ALL are in the right place without unnecessary of missing elements. Maybe you need to take a closer look to understand how it works...
Unnecessary icon.
Where..?
If you check the widget's folder you will see that there are 4 folders for the weather.
The "icons", "wth2" and "wth3" have 18 images and use the "${curWeatherIcon}" tag
"wth1" has 8 images and uses the "${curSimpleWeatherIcon}"
viewtopic.php?f=10&t=4837
Rain, little drops
Snow, little snow
Again..where?
Since the images use the "${curSimpleWeatherIcon}" tag, so the 8 image combination, the images empty or not should be there!
Most of them are "empty" because under these weather conditions the widget will show no graphics behind. So I did it like this on purpose.
I think that you're affected from the fact that the app doesn't work properly for you, because there are zero errors in the widget ;)
PostPosted: June 7th, 2015, 1:53 am
Unnecessary icon of weather.
Rain, little drops
Snow, little snow
On wtf1
I'll test this widget, because I like it. However I dump the subtitles and the place of their display to suit your needs. Just for myself. I hope you do not mind.
PostPosted: June 7th, 2015, 2:20 am
You can edit the widget as you wish on your phone, of course.
Rain, little drops
Snow, little snow
On wtf1
I repeat.. When you use a tag, any tag, for a weather in this case ("wth1" has 8 images and uses the "${curSimpleWeatherIcon}")
you MUST ADD ALL the images there that corrisponding the conditions! There is no matter if are "empty" images or with graphics.
So when the weather core will load the data, the images SHOULD be there to load.
Another case is like the backgound glass image for the v1 and v2. Check the Android versions...
How can we have an empty background image without show/hide script that not works on Android?
Creating an empty png! It's all about tricks man.
There is an explanation for everything. NOTHING is "unnecessary"... ;)
PostPosted: June 7th, 2015, 3:04 am
OK. :) I understand. I'm no expert in creating widgets.
PostPosted: June 7th, 2015, 7:04 pm
Good widgets, thanks for sharing.
Users browsing this forum: Bing [Bot] and 40 guests
