It is currently June 15th, 2025, 6:39 am
 Post subject: Accuweather S Widget v1
PostPosted: June 2nd, 2015, 10:00 am
Original design By "smoky-jr" from XDA.
http://forum.xda-developers.com/galaxy- ... d-t2712475
Update Weather (or use the button)
- SHOW/HIDE Glass Background
accuweather_s_widget_v1.xwp [8.93 MiB]
Downloaded 242 times
PostPosted: June 2nd, 2015, 10:10 am
Gold again. Great combo of graphics and transparency that doesn't cover the wallpaper. With all these great skins, I think XWidget needs a feature that will automatically change my skin every day. I already use Multipicture Live Wallpaper to do the same for my walls. XWidget feeds my short attention span. ;-)
PostPosted: June 2nd, 2015, 11:15 am
Two questions:
1. Maybe a stupid one, but how do I know if the glass is showing or hiding? When I click that toggle, I don't see any changes.
2. Does the clock you used have font available in order to make it a text object? I have a thing about leading zeroes for the hour (just my preference). I copied the samsungsansnum.rtf font into this widget to use it for now, but it would be cool to use the GS3 font that you used as image objects. No big deal, just a shot in the dark. Thanks.
PostPosted: June 2nd, 2015, 1:44 pm
sbs8331 don't forget that all the widgets that I post here are for PC. I make extra adjustments before post them in the app's gallery. This happens here too about the background Glass. The widget uses java script that is NOT SUPPORTED on Android! Runs this in your pc and you will understand what I mean.. ;)
PostPosted: June 2nd, 2015, 6:01 pm
Forgot, but it runs pretty well on my S5.
PostPosted: June 3rd, 2015, 12:07 am
All will run ok except the background show/hide glass option..
