It is currently June 15th, 2025, 6:25 am
PostPosted: May 26th, 2015, 12:34 pm
I had a slight revision of Jimking's great transparent GS5 Widget that I had posted here:http://bbs.xwidget.com/viewtopic.php?f=20&t=5577.
I tweaked it a bit more cosmetically to make it look more like the one for the GS5 Touchwiz launcher that was originally created by kimdalanxa and posted in XDA here: http://forum.xda-developers.com/showpost.php?p=52994223&postcount=1. The main difference between this and the original is that the location is moved to the left, which I felt just balanced it out a little, and conditions text added. Users can, of course, revise as they see fit.
The hotspots include:
1. On the city to change the location.
2. On the current temperature to go to the weather details.
3. On the update date/icon to refresh the weather.
Enjoy, and thanks both to kimdalanxa on XDA and Jimking here for the great original creations.
gs_weather_hd_transparent_2.xwp [10.28 MiB]
Downloaded 207 times
PostPosted: May 26th, 2015, 1:21 pm
Great work! ;)
Keep in mind that the galleries have 10mb limit. I have not check it yet, but you can use the weather tag for 18 weather icons instead of 44 to decrease the size.
PostPosted: May 30th, 2015, 6:27 am
Man, there are some useless items in the folder that you can delete.
But the size is always >10Mb.. :(
I will try to find a solution to decrease it a little..
PostPosted: May 30th, 2015, 7:01 am
Thanks.
PostPosted: May 30th, 2015, 10:00 am
Ok! I did this: I decrease the size of all the images in the "wth" folder 8% and then I used the "Image stretch and fit" to give the same old size.
When I moved your widget to my phone, there were visual "errors" with different shadows, maybe a little big fonts and bad alignments..
I fixed all this and here is the final version for ANDROID(I will post it to the gallery today) :)
I also put your name bro.
pm: There is a stupid bug. When we have digital clocks without the first "zero", and we want to use the "Left" text align bittons, the clock when it shows one number, goes right and not on the far left as it should. That's why I use almost this tag with the front zero "${Time0}". Anyway.. I kept your design without the zero..
gs_weather_hd_transparent_2.xwp [9.76 MiB]
Downloaded 206 times
PostPosted: May 30th, 2015, 11:30 am
posted to the official gallery :)
PostPosted: May 30th, 2015, 4:00 pm
Great! Thanks.
Users browsing this forum: Bing [Bot] and 40 guests
