It is currently June 15th, 2025, 6:45 am
 Post subject: Flash Clock
PostPosted: May 23rd, 2015, 3:40 am
Thanks to @Oletik for his help with the script code.
Widget with 3 Roundlines and a digital clock. What the particular with this "simple" clock?
* Continuous motion for the roundlines
* Multi-color. Double click on each roundline or the digital clock to edit the color/transparency.
NOTE: Pratically you can double click everywhere on each roundline, but to avoid difficulties is preferable to click on the point "zero" (12:00) for the RGB panel.
flash_clock.xwp [30.97 KiB]
Downloaded 195 times
Users browsing this forum: No registered users and 40 guests
