It is currently June 15th, 2025, 6:28 am
PostPosted: May 17th, 2015, 3:45 am
This is the rebuilt version of the widget, because the first one had high cpu consumption.
(original post is deleted)
Check the time pass like an open book....
Includes 2 versions: SECONDS and MINUTES according the time of the turning animation of the page.
NOTE: In the Min version, there is a little delay for the clock hands after the page flips, but depends on the XWidget engine.
The Book Of Time 3D Clock.zip [785.19 KiB]
Downloaded 264 times
PostPosted: May 17th, 2015, 7:20 pm
unfort minute version does not work properly for me.
see pic
http://i.imgur.com/5VwdTqr.jpg
Cheers, Pete
PostPosted: May 18th, 2015, 12:11 am
Fixed. Please download again, test and tell me if works ok now.
PostPosted: May 18th, 2015, 1:52 am
PERFECTOMONDO..
But I didn't expect anything less from you Jim.
All good!
Fixed.
Cheers, Pete
PostPosted: May 18th, 2015, 2:06 am
Ok! The min version is just a clone of the first one, only with different tag for the datetimecore. ;)
