It is currently June 15th, 2025, 6:25 am
PostPosted: May 16th, 2015, 4:32 pm
Based on the design by "woody/Lazy Swipe" app for Android.
Cool hidden multi-panel widgets with *27* customizable shortcuts divided into three categories:
SHORTCUTS - FOLDERS - INTERNET
*8* different styles:
Default, Red, Green, Yellow, Blue, White, Glow, Empty.
* PLACE THE WIDGET ON THE BOTTOM-RIGHT OF YOUR SCREEN
** CLICK ON TO SLIDE IN/OUT THE PANEL
** CLICK ON EACH "TITLE" TO CHANGE CATEGORY
Right click on each shortcut's icon for the Settings - Support for Drag-Drop files/folders
INFO ABOUT THE INTENET/BOOKMARKS SHORTCUTS:
To create a shortcut of our favourite website, just open the "Bookmarks" on your browser and drag-drop over the widget shortcut (+). Then right click on it to change its name.
You can find the default icons in the widget's folder.
Angular Multi-Panel Widgets.zip [2.24 MiB]
Downloaded 269 times
Users browsing this forum: No registered users and 41 guests
