It is currently June 15th, 2025, 6:32 am
 Post subject: EVGA Precision X
PostPosted: April 29th, 2015, 6:28 am
Inspired from the "EVGA's Precision X" overclocking card tool by NVidia.
* My initial thought was to add "CoreTemp" and "FanSpeed" cores to make it similar with the original. BUT XWidget, to show the values, needs two programs installed on the pc that should work on the background. So, I thought that was not a good idea make a widget that will work only in this way. So I made it more "simple" and full functional for all the pcs without any additional software. :)
** The widget is more fluid with some "switch animations" activated. BUT the cpu usage was high (~20-30%), so I deactivated them to make it more easy to use..
Use the buttons for:
- Shutdown
- Restart
- Sleep
- Open Task Manager
evga_precision_x.xwp [888.85 KiB]
Downloaded 216 times
 Post subject: Re: EVGA Precision X
PostPosted: April 29th, 2015, 5:26 pm
so good. Rocking!
Cheers, Pete
PostPosted: April 29th, 2015, 6:13 pm
Thanks Pete! :)
