It is currently June 15th, 2025, 6:29 am
 Post subject: Galaxy S6 Widget V2
PostPosted: April 1st, 2015, 7:16 am
- Change Location (or use gps the button)
NOTE:
If you want to use it for Android, please install XWidget
https://play.google.com/store/apps/deta ... ft.xwidget
and download it from the app's gallery.
galaxy_s6_widget_v2.xwp [1.54 MiB]
Downloaded 301 times
 Post subject: Re: Galaxy S6 Widget V2
PostPosted: July 30th, 2015, 6:26 am
I've been giving some thought for a while to how to eliminate the leading zero in the hour, given that these great shaded clock digits use images instead of text. I had created my own versions of S6 widgets, replacing the images with Samsung text. They look good but, of course, don't have the shading. I think I may have found a solution. On my copy of this widget, I created a separate folder "hourtens" into which I copied the "1.png" image from the "num" folder. I then created a fully transparent "0.png" image of the same size in the same folder. (I don't have Photoshop but was able to use Powerpoint). If one wants to use a 24-hour clock, copy "2.png" from "num" into "hourtens" as well. I then edited the image object "h1" and, under "Attributes", changed the "Core label" under "Bind Core" to "hourtens\${HourTens}.png". Seems to work per the attached screen shots.
I should note that I also moved the weather image up a bit an inserted the weather conditions text.
Users browsing this forum: No registered users and 41 guests
