It is currently June 15th, 2025, 7:22 pm
 Post subject: Realistic Weather Widget
PostPosted: February 10th, 2015, 5:31 pm
**Based on a design by cryo64.com**
- Select Style: DEFAUL or WITH SHADOW
* Mouse over the Forecast wth icons to show/hide the high-low temp and conditions of the day.
* Right click to select the style
realistic_weather_widget.xwp [2.24 MiB]
Downloaded 204 times
PostPosted: February 10th, 2015, 11:58 pm
the writes for example "rain and the ecc ecc." in the right bottom are unreadeable
PostPosted: February 11th, 2015, 4:16 am
What do you mean @andromeda1968..?
The forecast conditions/temperatures appears ONLY when you pass the mouse over the weather icons.
PostPosted: February 11th, 2015, 4:36 am
in android lollipop 5.0
PostPosted: February 11th, 2015, 7:20 am
@andromeda1968 keep in mind that ALL my widgets that are posted here, in this section, and on DA, are for PC ONLY!
I post the Android version of the widgets only through the official gallery of the app.
Now you can pass the widget to your phone of course by yourself..
In this case this show/hide feature for the text, is not supported on Android. If you edit the widget you will see that I used the "Binding Tooltip control" for this that is NOT supported on Android (I don't know for the next releases).
So, as you can understand it's not my fault... :)
PostPosted: February 11th, 2015, 9:51 am
ok perfect sorry...I understand now ;)
thanks again
