It is currently June 17th, 2025, 11:07 am
 Post subject: LG G2 WEATHER WIDGET
PostPosted: October 14th, 2014, 3:09 pm
Similar to G2 weather widget but perfect.
Can't upload what problem. You can download link via Google Drive.........
https://docs.google.com/file/d/0B3xLuu- ... cslist_api
Last edited by mkmkataria on October 15th, 2014, 8:01 am, edited 3 times in total.
 Post subject: Re: LG G2 WEATHER WIDGET
PostPosted: October 14th, 2014, 4:34 pm
Please use the package button of the designer after you finish the widget, and attach/upload the .xwp file..
I see from the screenshots that some elements are missing though...
Users browsing this forum: No registered users and 49 guests
