It is currently June 15th, 2025, 8:07 pm
 Post subject: Daily Widget
PostPosted: October 4th, 2014, 4:02 pm
An idea from a design by Freedom Design.
daily_widget.xwp [505.21 KiB]
Downloaded 221 times
 Post subject: Re: Daily Widget
PostPosted: October 22nd, 2014, 2:09 am
beautiful widget but ...
1 where is the weather today?
2 Unnecessary digital clock
4 Delete the date of the weather! Just the names of days
3 Weather Forecast should be on 5 days
4 should be at a minimum night temperature
4/5 stars
PostPosted: October 22nd, 2014, 2:34 am
3,5/5 stars
Thank you for your suggestions but there are no answers to your questions for the simple reason that THIS IS the design tomasov!
I wanted to do it like this and this your personal taste..
If you don't like it, XW give us the possibility to modify everything.
You can edit it as you wish (for personal usage)
PostPosted: October 22nd, 2014, 2:46 am
I can not edit and change as I like! :(
Why is there no weather for today only tomorrow etc
PostPosted: October 22nd, 2014, 2:56 am
As I told there is no "why"... I wanted like this.
You can edit the weather info easily so you can have
1st line: today weather
2nd line: tomorrow
3rd line: third day
..right..? I will concern your opinion when I will post it for Android. :)
Give me 5 mins and I will post your version..
PostPosted: October 22nd, 2014, 3:01 am
Here:
2nd line: tomorrow
3rd line: third day
Now for the rest edit the widget and delete the elements you don't like, like the "time" txt object for the digital clock.
THIS IS FOR PERSONAL USAGE ONLY.
daily_widget.xwp [505.17 KiB]
Downloaded 169 times
PostPosted: October 22nd, 2014, 3:09 am
My work
Hehe funny right? :)
PostPosted: October 22nd, 2014, 3:47 am
How to make a shadow to the end of the desktop?
I'm trying but I can't do it! :/
PostPosted: October 22nd, 2014, 3:48 am
Great! XWidget is great for this reason. Have fantasy and creation and you will have almost unlimited customizations.. ;)
PostPosted: October 22nd, 2014, 3:53 am
The designer has its own Shadow options under "Effect" tab. Or you can add it using and external image editor program like GIMP, like in this widget. The shadow tab of the designer has all the necessary modes/visuals you need.
If you need any help with the designing please for now use this section, not the topics:
viewforum.php?f=8
PostPosted: October 22nd, 2014, 3:54 am
I am not the author of this widget! I just put on top two other gadgets on your gadget :) sorry :)
Users browsing this forum: Bing [Bot] and 26 guests
