It is currently June 13th, 2025, 5:58 pm
 Post subject: Picto Man Set
PostPosted: July 28th, 2014, 9:39 am
*-> CPU-usage meter with 2-core dials
*-> MEM-usage meter with RAM-dial
*-> NET-speed monitor (resetable)
*-> Analog clock with second-dial
*-> Meteo-Panel (unit-switchable)
*-> Link-Dropper (multi-paged)
Best fits Tanipal WB/ICO themes
Image~ELECTROSELF~
 Post subject: Re: Picto Man Set
PostPosted: July 28th, 2014, 10:11 am
Download?
PostPosted: July 29th, 2014, 9:34 am
Let me know if you need it (PM); I'll send you link.
Image~ELECTROSELF~
PostPosted: July 29th, 2014, 9:37 am
It's not about whether I need it or not. Only I do not understand why not give the link, if you present your work.
PostPosted: July 29th, 2014, 10:57 am
Wiesz, czasami wydaje się dziwne, że w ciągu dwóch lat można zobaczyć w galerii tylko dwie z twoich widżetu, a reszta tutaj na forumie (gdzie zwykli użytkownicy nie często bywa). Więc po prostu informacje, coś na zrazek DEMO;)... Myślę, że nadszedł czas, aby przejść do DA.
Image~ELECTROSELF~
PostPosted: July 29th, 2014, 11:26 am
I understand. Actually, all the widgets should be in the gallery and not just those selected by the team. I just do not care something special, but I find it unfair that jimking widgets are all in the gallery, and, for example, mine are only two.
The fact that not everyone here look it, especially people using phones.
I add everything to the DA. :)
PostPosted: July 29th, 2014, 12:39 pm
Slavoo you need to understand some things. You're new here..
1) All these widgets by dezinto are made for pc, NOT for Android. On windows they show/work ok, and even the widgets that can work on Android, are too small so on screen will be all blur!
2)
If I remember well YOU told that you don't care about this, but only to share, right?
In the other hand, check better the Android gallery and you will see that your widgets ARE NOT only two!
Sorry but all the widgets have to be tested and optimized first. And your uploaded widgets are ported by me because there were some visual errors on screen. Sorry but I and Tony, we don't have all this time to edit other's widgets. If you want to give us a hand, the widgets must be created properly. I have already send you the instructions about some things, but you continue to ignore them. So it's not mine or any other here fault..
It's not true. And don't forget that XWidget first of all is a PC program!!
PostPosted: July 29th, 2014, 1:09 pm
I have no pretensions. :)
Most of my widgets running on Android because I checked. Especially those that have a resolution of 700x ...
The fact that I'm new and do not know the rules, but if the widget works fine on Android it should be added to the gallery. Just my objective opinion, regardless of whether I care to add my widget to the gallery or not. It was here that does not matter.
With the rest, is a priority for me DA.
PostPosted: July 29th, 2014, 1:18 pm
I have one question only. Is this widget suitable for gallery or not?
viewtopic.php?f=11&t=4883
If not, why not?
With me on the phone works great.
I do not understand "optimization". Optimization of what? In what way?
All for subtitles are sufficiently large, so as to fit the subtitles in different languages​​.
PostPosted: July 29th, 2014, 7:19 pm
Slavoo, perhaps I forgot to warn you - "don't boil this water". It's very COMPLICATED, MESSED and MISUNDERSTANDING question. And it's better leave things to flow themselves.
Image~ELECTROSELF~
PostPosted: July 29th, 2014, 10:50 pm
I just wrote my objective opinion.
Regards!
PostPosted: July 30th, 2014, 9:20 am
Slavoo ALL the widget that are posted here, on DA or on chinese forum are NOT suitable to the galleries! And the reason is simple:
Because to upload a widget there, needs an extra specific uploading process to another chinese server, where only the staff, and not all, have access to it. The official galleries and the whole system here works like this and the things cannot be changed.
At the end,as I said, the 95% of the widgets that work on Android need TESTING (text position, size, shadows, tags/codes, hotspot,default image). So as you understand (I hope) the things are not so simple as they seem..
PostPosted: July 31st, 2014, 9:18 am
OK. I understand.
Users browsing this forum: Bing [Bot] and 20 guests
