It is currently October 23rd, 2026, 9:03 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
 Post subject: LG G3 Widget
PostPosted: June 10th, 2014, 4:22 pm
The weather clock widget from the new LG G3.
Click on:
- The "accuweather.com" to open the webpage
- The "arrow" button to Update Weather
- The "settings" button to Change Location
- The "circle" button to check the Weather Details
lg_g3_widget.xwp [358.27 KiB]
Downloaded 391 times
 Post subject: Re: LG G3 Widget
PostPosted: June 10th, 2014, 11:24 pm
great job friend thanks !!!!!
PostPosted: June 11th, 2014, 2:02 am
You're welcome..
PostPosted: June 11th, 2014, 4:52 am
I just learn to edit widgets...but how can I do to create or modify the UPDATE icon ???
Many widgets dont' work this option...
help me please :=
PostPosted: June 11th, 2014, 5:40 am
for example these 2 "my own" widgets don't update the weather when push the icon
https://hostr.co/0tv4TaMBjkgO
https://hostr.co/IGnJomJqnfnB
why? !!!!
PostPosted: June 11th, 2014, 6:01 am
why? !!!!
I didn't check the widgets, I can tell you this:
You can use the "button" or the "image" component.
For both cases you need to do these steps:
- Select Binding core -> accuweathercore
- In "Cursor" sub-tab select "Handpoint"
- And in the Functions Tab, at "OnClick" select "!UpdateWeather".
That's all!
I don't know for the other's, but ALL my widgets have this function and works 100%!
You can check the update time though the "Weather Details" window.
(right click option)
pm:
Please use the "Help: XWidget Skins/Widget" section for these matters...
PostPosted: June 11th, 2014, 6:14 am
thanks ;)
Users browsing this forum: Google [Bot] and 105 guests
