It is currently June 16th, 2025, 8:33 am
Post new topic Reply to topic  [ 14 posts ]
 Post subject: Eye on Weather (edited)
PostPosted: April 14th, 2014, 10:28 am
Weather widget with 4 0 beautiful real images/photos for the weather conditions.
ALL THE IMAGES ARE COLLECTED AND OPTIMIZED BY ME.
EDITED the file extension on an image in case that there was a incompatibility for the tag/code.
eye_on_weather.xwp [3.1 MiB]
Downloaded 148 times
 Post subject: Re: Eye on Weather
PostPosted: April 14th, 2014, 4:07 pm
nice HD widget
just there is a problem:
and just i found another:
pictures are named to 44, but it has 40images,
so it doesn't have 9,10,27,28
edit: just i found that they're null, so this one is not problem
PostPosted: April 14th, 2014, 4:36 pm
hamid wrote:
nice HD widget
The wth images/numbers must be like this man! :lol:
Check:
viewtopic.php?f=3&t=2689
For the image 41, has same file type format .jpeg. I checked again.. All the images are edited with ACDSee so I'm sure.
For this file type the tag must be "folder name/${curSimpleWeatherIcon}.jpg" and the program recognize all the images. :)
Trust me! ;)
PostPosted: April 14th, 2014, 5:07 pm
the extension for image 41 is wrong:
if you don't have file extension in your explorer:
>in windows you can go to:
tools>folder options>view>uncheck [hide extension for known file types]
>or use a file manager or tool that shows extensions (like: winrar , 7zip)
PostPosted: April 14th, 2014, 5:30 pm
I know what do you mean... But here is a screenshot to see that all the images have the same file extension:
If there was an incompatibility between tag and the file extension of the images, the images will not work at all.
From my experience of making widgets I think that XWidget recognize .jpeg and .jpg as the same file.
I always use this method for ALL my wth widgets.
PostPosted: April 14th, 2014, 5:47 pm
first of all: some definitions:
-extension: related to naming
-format: related to file structure
-file type: related to description of file and program associated with it
in your picture:
it just view the file type (some info about file and associated program)
you can view all images because .jpg and .jpeg are same format (jpeg format)
but xwidget can't access the file that have .jpeg extension but linked .jpg in coreformat
(wth\${curWeatherIconNum}.jpg)
you should:
1. enable file extension in your explorer to see the difference (or use a tool similar)
2. and rename the .jpeg to .jpg to fix the problem
PostPosted: April 14th, 2014, 5:59 pm
in your picture:
Sorry man but you will blow my mind! :lol:
I used (every time I do the same thing) this tag
In my pic you see that all the images are in .jpeg file format, right?
As you wrote:
So??? Since are the same format XWidget recognizes BOTH!
I made a test renaming the tag to wth\${curWeatherIconNum}.jpeg and all the images are work the same way!
If there is a bug it should work only the one image with the "wrong" file format!
All the widgets that I made and all the weather widgets from others who use .jpg images use this tag!
PostPosted: April 14th, 2014, 6:14 pm
Anyway! I unchecked the explorer option for the known file extensions and I'm doing it....
PostPosted: April 14th, 2014, 6:20 pm
File updated! :)
Now it's ok?
PostPosted: April 14th, 2014, 6:40 pm
now, it's ok
thanks
PostPosted: April 14th, 2014, 11:49 pm
Suggestion:
I would rather narrow to the 19 provided by ${currentWeatherIcon} or ${currentSimpleWeatherIcon}... The 44 icons are mostly duplicate of each other... Inflating the file size
PostPosted: April 15th, 2014, 3:17 am
digigamer wrote:
Suggestion:
I know it DG(!) but since the file size was under 10Mb I preferred to have more variety for the weather conditions.
I used the "simple" tag for the "Sexy Edition".
PostPosted: April 20th, 2014, 6:30 pm
You could upload 10 megs here... ??
EDIT: Oh!... you're a mod here... ;)
PostPosted: April 21st, 2014, 2:24 am
Yeap! :D
Users browsing this forum: Bing [Bot], Google [Bot] and 42 guests
