It is currently June 16th, 2025, 11:41 pm
PostPosted: April 3rd, 2014, 5:47 pm
A special FULL SCREEN widget with ANIMATED PISTONS and CLOCK GEAR!
CLICK ON:
- Red Button to Shutdown
- Yellow Button to Sleep
- Green Button to Reboot
- Turn Animations ON/OFF
NOTE:
Turning on the animations you will have a small increase in cpu consumption.
(I tried to for the best possible balance between cpu consumption and smoothness of the animations. I wanted to add more animations, but it was not practically possible.
I hope that the v2.0 of XWidget will give us the possibility to add more animations with less memory consumption)
---FITS ON 1366x768 RESOLUTION---
mechanical_desktop.xwp [5.18 MiB]
Downloaded 185 times
Users browsing this forum: Bing [Bot], Google [Bot] and 22 guests
