It is currently June 14th, 2025, 9:36 pm
PostPosted: February 9th, 2014, 11:44 am
Another cool widget for your desktop! 8-)
* Click on to "put" your fingerprint and start scanning!
After that the password panel will show up, and you have to put the 5 DIGITS PASSWORD to unlock your shortcut (file or folder).
--THE DEFAULT CODE IS 12345--
- Shortcut settings (support for drag-drop function, use can put a single file or folder)
- Change the password (confirm the old code-write the new one)
- Re-Lock/Hide the fingerprint and password panel.
NOTE:
* The widget provides a security function, but the code is not unbreakable. So it will NOT provide a true security for your files.
Only who will install this on his/her computer will know the "trick"
* To reset the password close the widget.
* To Lock/Hide again the fingerprint and password panel, right-click and choose "Lock It"
fingerprint_shortcut_widget.xwp [1.13 MiB]
Downloaded 138 times
Users browsing this forum: No registered users and 39 guests
