It is currently June 14th, 2025, 7:39 pm
 Post subject: XWRobot Widgets Pack
PostPosted: November 30th, 2013, 1:53 pm
Robot Meters for your desktop! Watch the Robot changes its expressions depending on the percentage! :D
CLICK ON EACH WIDGET TO SHOW/HIDE THE PROGRESS BAR/PERCENTAGE.
Includes 6 widgets:
- HDD (right click for Change Disk)
- CPU
- RAM
- SWAP
- VOLUME
- BATTERY (with charging status. The eyes of the Robot will glow when charging)
To add multiple HDD widgets:
Then right click on the 2nd, 3rd.... widget a click select drive.
XWRobot Widgets Pack.zip [991.82 KiB]
Downloaded 230 times
 Post subject: Re: XWRobot Widgets Pack
PostPosted: December 1st, 2013, 8:36 am
File uploaded! :D
Users browsing this forum: Bing [Bot] and 39 guests
