It is currently June 16th, 2025, 12:11 pm
PostPosted: November 14th, 2013, 8:43 am
Feel the experience of using the last version of Android OS "KitKat" on your computer! :D
PLEASE WATCH ALL THE SCREENSHOTS AND CHECK ALL THE PARTS, FUNCTIONS AND OPTIONS OF THE WIDGET...!!!
FEATURES
1) Real Android homescreen
2) Android style expanding status bar with the follow informations:
- Window Task Manager
- Current temperature
- GMail count
- CPU meter -> WIFI icon
- RAM meter -> SIGNAL icon
- Battery icon with charging status icon
3) Google Search bar
4) Total 2 1 customizable shortcuts using real Android icons from KitKat OS.
RIGHT CLICK FUNCTIONS:
- Search city
- GMail settings
- Open GMail
- Refresh mail
- Right click on each shortcut to edit/change it OR just drag your file/folder to set it.
CLICK ON FUNCTIONS:
- On the Android icon (top-left) to open the Windows TaskManager
- On the envelope icon (top-left) to open the GMail site
- Everywhere on the transparent status bar to open the ANDROID STATUS BAR / SLIDEPANEL
- On the three buttons on the dock (bottom) to RESTART, SHUTDOWN and SHOW DESKTOP.
STATUS BAR / SLIDEPANEL FUNCTIONS:
- Click on the settings icon to Search your City
- Volume control and Mute ON/OFF button
Click on the top "dock" or on the arrow on the bottom of the panel to SLIDE IN/HIDE.
N O T E:
The .zip file contains 2 more widgets:
The "Android KitKat Shortcut" and the "Android KitKat Folder" so you can extra elements on your homescreen and enjoy the full Android experience! :D
ANDROID KITKAT SHORTCUT:
Right click on the shortcut to edit/change it OR just drag your file/folder to set it.
ANDROID KITKAT FOLDER:
Click on to open/close the folder with nice animations.
Just click on the shortcut/s you want to add in the folder and drag them on the folder.
NOTE: If you see that the icons are not straight in the folder after that, close and open it again.
- Right click on each shortcut for the settings.
- Right click or click ON the "X" to delete all the shortcuts.
IF YOU WANT TO DOWNLOAD THE ANDROID KITKAT FOLDER SEPARATELY, YOU CAN FIND IT HERE:
viewtopic.php?f=11&t=3770
IS A FULL SCREEN WIDGET SO PLEASE USE THE "BOTTOM" POSITION and LOCK THE POSITION:
Right click > Window > Position > Bottom
Right click > Window >Lock Position
SO ALL THE NEXT WIDGETS WILL WORK ON TOP OF IT! ;)
--------------------------This is for 1 3 6 6 x 7 6 8 resolution--------------------------------
Android KitKat Launcher.zip [2.61 MiB]
Downloaded 316 times
PostPosted: November 17th, 2013, 4:25 am
This is nice bro! ;)
PostPosted: November 17th, 2013, 5:46 am
Thanks man!
Users browsing this forum: Bing [Bot] and 44 guests
