It is currently June 15th, 2025, 7:20 pm
PostPosted: November 9th, 2013, 9:59 am
Original weather icons by MCLaffer. Resized and optimized by me.
An Android style clock/weather widget with ANIMATED WEATHER ICONS! :D
- Update weather
- Search city
- Change temp unit.
animated_purity_clock_weather.xwp [2.57 MiB]
Downloaded 288 times
PostPosted: March 31st, 2015, 9:58 am
Greetings. I'm fairly new to XWidget and have been playing around with different skins and performing some modifications. I thought I'd give this one a try on my rooted AT&T Galaxy S5 SM900A running 4.4.2 (DynamicKat Rom). I've installed from downloads both from this site and from DeviantArt, but I can't get the weather conditions image in the middle to display. I also don't see any images in the list of objects, only text objects. Am I doing something wrong? Thanks for all the very nice skins to try. Regards.
PostPosted: March 31st, 2015, 12:22 pm
Hi sbs8331 and thank you for using XWidget.
This particular widget uses animated pngs and script code that are NOT supported on XW for Android.
So it's logical that the widget not works properly on your phone...
Edit :I have already posted a working version of this widget in the gallery, but without animations for the weather icon. Please search for the "purity" widgets in the gallery :
http://android.xwidget.com/plus/search. ... type=title
(for the next version we plan to add the 'search' option to find more easily the widgets)
