It is currently June 17th, 2025, 1:51 pm
PostPosted: September 23rd, 2013, 7:23 pm
Original design and idea from "Winapp 4.0" by "blueonegermany" for Rainmeter.
THIS IS THE BLACK VERSION of my "Windows Unitab Full Screen" widget.
A stylish full screen widget for your desktop! :D
THE WIDGET HAS A LITTLE TRANSPARENCY FOR MAKE THE BACKGROUND WALLPAPER VISIBLE! ;)
Includes:
- Clock / Date
- Photo Album
- Calendar / Notes (x7) / use the arrows to go to next/prev month
- Weather / 4-Days forecast
- System info (hard disk, battery, cpu, ram, net, recycle bin)
- Logoff, Restart, Shutdown commands
- Shortcuts (customizable x30)
- Open photo
- Next/Prev photo
- Update weather
- Search city
- Shortcut settings
- Search cover tool
- Edit music tags
- Add song
- Close player
- Open trash
- Clear trash
Click the various "buttons" next to each panel for open the extra options:
Photo Album -> settings
Calendar: -> Notes panel
Player: -> settings
Weather: -> 4 Days Forecast panel
Shortcuts: -> 2nd panel with shortcuts
PLEASE CHECK THE SCREENSHOT FOR THE SECONDARY/HIDDEN PANELS)
This is for the white version, but all the panels are modified with black colour!
http://i43.tinypic.com/16gmttf.png
NOTE: Use the "Bottom" position for the widget! (right click menu)
............................THIS IS FOR 1 3 6 6 x 7 6 8 RESOLUTION..................................
windows_unitab_full_screen_black.zip [3.29 MiB]
Downloaded 177 times
Users browsing this forum: Bing [Bot] and 52 guests
