It is currently June 14th, 2025, 2:48 pm
 Post subject: Steampunk Orrery Xwidget
PostPosted: August 11th, 2013, 3:25 pm
You are probably aware of this one already. It's been around a while, in fact we created when Xwidgets were brand new and before this forum was created. I'm not sure if we ever posted this one.
I am just about to make some changes to the way the whole thing animates so it corresponds with this one:
http://www.youtube.com/watch?feature=player_embedded&v=qJayRGScmcY
I have this widget for Yahoo widgets, Xwidgets, KDE Plasmoid and as a Rainmeter skin as well as being embedded on my site in javascript.
timekeeper.XWidgetPkg [1.13 MiB]
Downloaded 185 times
PostPosted: August 12th, 2013, 3:14 am
Great idea and work!!!
Unfortunately the XWidget version as I see supports only one mode, the mouse over function for the movement of the external ring that is not so smooth..
Also it will be better if you can add the "turn to today" button.. Without this, the widget is hard to use..
For the rest functions I'm afraid but we need a more expert person.. Just take a look at the widgets of Windows Media Player-XWidget version to see what XWidget engine can do! ;)
Thanks for sharing though...
PostPosted: August 13th, 2013, 6:00 am
Thanks Jim,
The widget will be brought up to date to keep it in line with the plasmoid widget and the update Yahoo widget that I will be releasing shortly. I'll get to the Xwidget version shortly. Glad you like it.
Users browsing this forum: Bing [Bot] and 35 guests
