It is currently June 15th, 2025, 10:24 pm
PostPosted: June 15th, 2013, 7:32 pm
Includes 5 Gauge Widgets:
CPU
RAM
HDD
SWAP
BATTERY
On HDD widget right click for select the drive.
To add multiple HD widgets:
Then right click on the 2nd, 3rd.... widget a click select drive.
Glossy Gauge Mini Pack.zip [574.13 KiB]
Downloaded 206 times
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
