It is currently June 15th, 2025, 10:28 pm
PostPosted: June 6th, 2013, 3:03 pm
Original design by VClouds and his "Glasses" widgets for Rainmeter.
http://vclouds.deviantart.com/art/Glasses-313182310
The famous VClouds widgets now for XWidget + EXTRA widgets made by me! :D
INCLUDES 14 WIDGETS:
- Clock (2 variations)
- System
- Net
- Hard Disk/s
- Recycle Bin
- Volume
- Weather (2 variations - horizontal and vertical)
- Music Player
- GMail
- Notepad
- RSS (with 4 feeds)
- Photo Album
- World Clock
FUNCTIONS
- Hard Disk:
To add multiple HD widgets:
Start the HDD Widget, Right click-> Start Same Widget.
Then right click on the 2nd, 3rd.... widget and click select drive.
- Recycle Bin:
Right click for Open / Clear.
- Volume:
Click on "+" or "-" to increase / decrease the volume.
Click on "Mute" to turn on/off mute.
- GMail:
Right click for GMail Account setting or Refresh mail.
Click on "Open.." to open GMail webpage.
- Weather:
Right click for Update, Search City and change temp unit C/F
Click on "gear" to search city.
Click on the "arrow" (top right) to change the position.
- Photo Album:
Right click for Photo Album Settings and for Open Photo.
Click on the left or right part of the image to go to prev/next photo.
- RSS:
Click on the RSS titles for change panel.
Click on the titles to open the webpage.
Right click on each title to RSS settings.
- Notes:
Click on each line to add your text.
- Music Player:
Right click for player settings, search cover, edit tags, add songs.
- World Clock:
Click on the "arrows" to open/edit the various time zones.
NOTE: The widgets are bigger than the screenshot. I had to open them on 80% to take a screenshot with all panels.
FIXED: 7/6/2013
I fixed the wrong code for Total/Used RAM memory and the invert position of the codes in HD widget.
PLEASE DOWNLOAD AGAIN!!!
Glasses (vclouds) Widgets Pack.zip [4.9 MiB]
Downloaded 510 times
PostPosted: June 6th, 2013, 4:09 pm
PostPosted: June 6th, 2013, 10:45 pm
jimking wrote:
I wanted to use this function for the Net widget in this pack:
viewtopic.php?f=11&t=3196
Hi jimking,
your link above leads back to this topic again.
By the way, I noticed that system information shows 2 GB RAM while I have 8 GB RAM installed.
Another thing is, that Up- & Download don't show any graph (while the original does).
I specially like your separat digital clock which originally was not existing before.
PostPosted: June 7th, 2013, 5:18 am
Hi jimking,
For the system information you're right, I fixed this! :!:
I also fixed the invert position of the codes in HD widget.
Download Again!
For the Up/Down maybe you mean the arrow that MAYBE flashes in the original. I don't know the script to do this..
And with all the hard work behind this pack I don't think that is so important!
PostPosted: June 7th, 2013, 6:57 am
Hi jimking,
we need to clarify the terms for graphs and bars:
PostPosted: June 7th, 2013, 8:27 am
I already talked about this in DA Cov! Why posting the same things here too....! :o
I used to talk in terms of the XWDesigner so I understand exactly for which component you're talking about! :!:
Anyway, I zoomed in the screenshot from the original and at the end I saw the charts behind the UP/DOWN. Were really hidden!!!
But ok is not a big deal, even because with xwidget I had to put the % code so they will not shown the real values...
PostPosted: June 7th, 2013, 8:48 am
Because you started with doing this. I don't understand why this is a problem for you.
No, you didn't ...
PostPosted: June 7th, 2013, 8:55 am
I sent you a second note on DA about it! Maybe you have not received it....
Absolutely there is not a problem discuss it! I just thought that is a bit useless repeat the same things when WE're already talked about them in DA...
That's all!
PostPosted: June 7th, 2013, 10:39 am
PostPosted: June 7th, 2013, 1:37 pm
Thanks for this particular info. As I told you I don't now how to "copy" this funtion and if this can work with XWidget needs a special script code..
If anyone can help with this.....
PostPosted: June 11th, 2013, 1:55 pm
DOWNLOAD THE FIXED VERSION OF THE WEATHER WIDGET FROM HERE:
viewtopic.php?f=11&t=3230
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
