It is currently June 16th, 2025, 7:16 pm
 Post subject: Real Lamp Widgets Pack
PostPosted: May 22nd, 2013, 8:20 am
Check your system's status with a real lamp. :D
----Higher the value = brighter the lamp!----
Includes 4 widgets: CPU, RAM, HDD and VOLUME.
On HDD widget right click for select the drive.
On VOLUME widget click on the lamp and then use the mouse wheel to change the volume.
To add multiple HD widgets:
Then right click on the 2nd, 3rd.... widget a click select drive.
Lamp Widgets.zip [3.25 MiB]
Downloaded 172 times
Users browsing this forum: Bing [Bot] and 32 guests
