It is currently June 15th, 2025, 7:14 pm
 Post subject: LG Optimus Only Weather
PostPosted: May 12th, 2013, 10:44 am
- Search City
- Refresh Weather
- Change temp unit C/F
lg_optimus_only_weather.part2.rar [1.03 MiB]
Downloaded 209 times
lg_optimus_only_weather.part1.rar [1.91 MiB]
Downloaded 203 times
PostPosted: March 25th, 2014, 5:10 am
Sorry if I'm posting this in the wrong location. This widget is featuring the following issue with version 1.9.0.318 of XWidget. When suspending Windows 8.1, when returning, he no longer updates the temperature being necessary to restart the program to return to work.
PostPosted: March 25th, 2014, 6:49 am
Hi flaviobh. Thank you for your report. This is the weather/update bug of the versions 1.8.8.xxx of XWidget. It seems that sometimes loses communication with the accuweather server. When you notice this, just restart XWidget from the icon tray (right click on it) and then all will work ok.
Today I checked for an update after your post, and I see that there is a new v1.9.0 where the Dev reports that the issue of the 0 temp is fixed..I have Win7 so I can't test it..
Please next time post in the "Bugs & Feature Suggestions" section.
Users browsing this forum: No registered users and 23 guests
