It is currently June 15th, 2025, 3:53 am
 Post subject: TEXT WIDGET SUITE
PostPosted: May 2nd, 2013, 2:13 am
This is the next release of another minimal widget suite. This version was unplanned but it's mostly about bug fixing.
This is a minimalistic widget with text with bare minimum flattened icons. Hope you enjoy... :x
Special thanks to jimking and qiancang who helped me in fixing some bug around the Text Weather and the Text Cover widgets.
File comment: Screenshot
* Unzip the file and double click to install the widget theme.
Download:
File comment: Theme Package
Text_Suite.zip [255.19 KiB]
Downloaded 342 times
 Post subject: Re: TEXT WIDGET SUITE
PostPosted: May 2nd, 2013, 3:51 am
nice work!
two problems with the music player:
1) playercontrolcore updates when widget starts,so tutton1 is unvisible all time.
2) one more easier way to position tip, example: http://qiancang.deviantart.com/art/SeekVolumn-348650117
and i think upload one .xthemepkg file is better than .zip
PostPosted: May 7th, 2013, 5:17 pm
I'll fix it...
I also thought to upload an xthemepkg but they files are uncompressed, so quite a large. In my case, it was about ~650 kb. While the zip was 90kb. I think xwidget should compress packages. They are already based on zip format, so adding compression isn't a great deal.
And thanks for your tip, I tried that trick too, but since my tooltip is autosized, that didn't work.
PostPosted: May 7th, 2013, 5:53 pm
qiancang wrote:
nice work!
All bug-fixing is complete. I have tested it on Windows Media Player (I don't use any other player supported by XWidget). Previously it was working but, the recent xwidget update broke my code!. Please see and tell if you face any more problems.
One more thing, XWidget SUPPORTS MediaMonkey. But unofficially with this little trick. In fact, MediaMonkey uses Winamp player internally, so Winamp configuration works for it. Select player type to Winamp and point it to MediaMonkey exe. Trick works. But most people don't know this. So it will be better if XWidget adds MediaMonkey to the list of supported player.
Users browsing this forum: No registered users and 35 guests
