It is currently June 15th, 2025, 7:49 pm
 Post subject: CMD Meter Widget
PostPosted: April 22nd, 2013, 9:14 am
(an idea from "cmd meter by starburstspectrum-d5ncbxf)
System Info + 12 customizable shortcuts. (right click to edit or drag your file/folder)
- Search City
NOTE:
If you have more than one hard disc drive/cpu you need to right click->Edit and change the code manually.
cmd_meter_widget.zip [50.16 KiB]
Downloaded 209 times
 Post subject: Re: CMD Meter Widget
PostPosted: April 29th, 2013, 9:33 pm
Hi, this is great!
I'm surprised how much creativity poeple have.
A few remarks:
PostPosted: May 1st, 2013, 12:00 am
NOTE:
I did it like this because when there is no extra HDD drive/CPU the value is not appears correctly. Read this:
viewtopic.php?f=3&t=2976
The "Bin" values are actually the Recycle Bin! ;)
Yes, the virtual buttons are not "functional". There is no sense add "X" for close the widget and there is no function on XWidget to minimize/maximize widgets! :)
PostPosted: May 1st, 2013, 7:35 am
jimking wrote:
NOTE:
Ah, ok .. I have tried to add "binding core" on the second drive but I can't figure it out now, will do later.
By the way, when clicking on any frame within the widget in the edit mode, it easily changes size of the frames by accident.
I think it's really difficult to get them alligned again. Is there a trick how to allign the frames?
I did it like this because when there is no extra HDD drive/CPU the value does not appears correctly. Read this: viewtopic.php?f=3&t=2976
Oh, I see
Ok, now I understand. Very good idea actually!
No problem at all.
I was just thinking of the design:
There are so many different Visual Syles existing, we cannot expect to have matching design for all.
Users browsing this forum: Bing [Bot] and 24 guests
