It is currently October 23rd, 2026, 10:35 am
PostPosted: April 5th, 2013, 6:28 pm
Check your current weather + 6 days forecast by Accuweather.com or use the working (realtime) internet html panel by Google to check the map/satellite,
local or world conditions and not only! (Write the name of your city in the search bar) :)
- Update weather
- Search City (or click on "Search Button" on the right)
- Choose temp unit C/F
----------1 3 6 6 x 7 6 8 resolution-----------
N O T E:
When you open the skin there is a possibilty to see the html panel a little off position.
Just adjust the position of the widget, right click "Window->Reload..." and it will be fixed!
realtime_internet_weather.zip [4.82 MiB]
Downloaded 300 times
Users browsing this forum: Google [Bot] and 175 guests
