It is currently June 15th, 2025, 5:21 am
 Post subject: Sticky Numbers Clock
PostPosted: March 29th, 2013, 8:32 am
A different sticker for every digit! ;)
- Search City
- Change temp unit C/F
1/4/2013: The widget was downloaded 255 times! :D
I forgot an unrelated file in the widget's folder. The widget is only 294.97 KB now! Please download again.............
sticky_numbers_clock.zip [294.97 KiB]
Downloaded 177 times
 Post subject: Re: Sticky Numbers Clock
PostPosted: March 29th, 2013, 5:29 pm
Awesome! I like this! Thanks for sharing :)
PostPosted: March 29th, 2013, 5:47 pm
Please remove the "WldOb0xt_mobilism.org.apk" file in the zip file folder "num" :)
PostPosted: March 31st, 2013, 2:53 pm
My bad! :lol:
I fixed and posted the "clean" file... :)
Thank you for your help...
Users browsing this forum: Bing [Bot] and 39 guests
