It is currently June 14th, 2025, 2:34 am
PostPosted: March 22nd, 2013, 8:25 pm
- Full system info (cpu, ram, hdd, net, recycle bin) with various visualizations: dashboard, chart, pie)
- Volume control (use your mouse wheel on the volume-blue pie)
- Current Weather + 3 days forecast
- 14 shortcuts all customizable
-12h/24h
- Edit/Change the various shortcuts (or drag your file)
- Search City
- Change temp unit C/F
- Open/Clean ReycleBin
Don't worry for the cpu/ram consuption. This works like a normal widget with ~zero resources!!!! ;)
............................THIS IS FOR 1 3 6 6 x 7 6 8 RESOLUTION..................................
system_dashboard.zip [2.02 MiB]
Downloaded 215 times
PostPosted: March 23rd, 2013, 1:48 pm
Impressive..... :)
PostPosted: March 23rd, 2013, 1:58 pm
Thanks again!
