It is currently June 15th, 2025, 6:27 am
PostPosted: March 18th, 2013, 1:34 pm
Press the Eye of Ra and discover the secret of the Sarcophagus..!!! :D
6 customizable shortcuts (right click for edit/change/set the shortcut or drag you file to set)
You can download the Egyptian Icons from here:
http://www.general-files.com/files-e/eg ... 2536015079
sarcophagus.zip [2.05 MiB]
Downloaded 234 times
