It is currently June 15th, 2025, 6:29 am
 Post subject: Windows Seven Start Menu
PostPosted: March 13th, 2013, 8:17 am
A FULL FUNCTIONAL Start Menu Windows 7 style, with working hidden panels/menus like the real one! (see screenshot) :D
- Current Weather
- 7 shortcuts + 7 like the default/real ones all customizable.
- Internet Search Bar.
- Volume panel: Click on taskbar icon to show/hide, control volume or click on panel's icon to mute.
- Calendar: Click on clock/date on taskbar to show/hide, navigate between months or open the datetime settings.
- System Control: Click on "Shutdown" or use the arrow to show/hide the Logout,Lock or Restart options.
- Hidden panel: Click on "All Programs" to show/hide the second panel with system info (HDD,Ram,Cpu,NetDownload,NetUpload) and details for current Weather.
- Edit the various shortcuts or drag your file
- DateTime settings, 12h/24h
- Seach City, choose the temp unit
windows_seven_start_menu.zip [2.62 MiB]
Downloaded 346 times
PostPosted: March 13th, 2013, 8:56 am
WAW ! It looks amazing, i'll try itin the minute !!!
Thanks for sharing !
Just a french guy loving computers ^^ !
Find me on DA : http://bebert135.deviantart.com/
PostPosted: March 13th, 2013, 9:03 am
you are crazy man... :)
PostPosted: March 13th, 2013, 2:24 pm
Thank you guys!
