It is currently October 23rd, 2026, 9:45 am
PostPosted: March 6th, 2013, 6:43 pm
A unique widget for XWidget...
A FULL SCREEN Weather widget with full info, in HD images for the current weather conditions and Digital Clock/Date!!! Hide the taskbar for full experience.
The file size is a bit large for a widget, but this is obvious because all the background images (that are collected by me) are in HD.
Don't worry for the cpu/ram consuption. This works like a normal widget with ~zero resources!!!! ;)
N O T E :
You can check the weather images (after the installation) inside the widget's folder (Documents->xwidget->Widget->Read Weather HD Full Screen)
- Search City
- Change temp unit C/F
............................THIS IS FOR 1 3 6 6 x 7 6 8 RESOLUTION..................................
IMPORTANT:
For use the widget you need to download ALL the 8 parts. The file was too big for upload in a single post...
To download the rest 4 parts/.zips see here:
viewtopic.php?f=11&t=2697
read_weather_hd_full_screen.part4.rar [3.81 MiB]
Downloaded 307 times
read_weather_hd_full_screen.part3.rar [3.81 MiB]
Downloaded 296 times
read_weather_hd_full_screen.part2.rar [3.81 MiB]
Downloaded 290 times
read_weather_hd_full_screen.part1.rar [3.81 MiB]
Downloaded 309 times
PostPosted: March 6th, 2013, 6:48 pm
Awesome! very cool! :)
PostPosted: March 8th, 2013, 8:03 am
excellent work! \(^o^)/
Users browsing this forum: Google [Bot] and 101 guests
