PostPosted: February 19th, 2013, 10:08 pm
There are 6 widgets in Leaf&Woo(x)d for Xwidget. *If you try to click the Leaf, you can get much more things.And there are 9 leaves colors and 16 wood grains that you can choose in every widgets with Right-click menu.
- Clock(you can click the leaf button and flip to the date)
- Player(when the player plays music, the snail move with a flash. And just try to click the leaf button. And this player flash was port from Davlikanoff Design's Helixbar http://dribbble.com/shots/541530-Helixbar)
- Note (Just a note with the size grip. And you can get one more when you click the leaf)
- Album (It also has with the size grip. And you have album setting with the leaf button)
- Dock (Drag how many shortcuts that you want on the dock if you wanna use them. And in the middle of bottom, there is Page indicator. They are gray and red line segments. Or you can use the mouse wheel. And the leaf is for Recycle Bin)
- Bar (There are the Calendar, Weather, Search bar, Shutdown button, CPU, RAM and Network speed data on the bar)
Go to DA to download: http://9yomo.deviantart.com/art/Leaf-an ... a_recent=1
Users browsing this forum: Google [Bot] and 241 guests
