It is currently October 23rd, 2026, 10:35 am
PostPosted: September 24th, 2012, 12:13 am
BR 01-97 RESERVE DE MARCHE
BR0197-BL-ST
To create the BR 01 aviation watch, the designers drew inspiration from aeronautical instrumentation, the undisputed benchmark in terms of legibility and reliability.
Movement: mechanical automatic.
Functions: hours, minutes, seconds. Date. CPU indicator
Case: XL Diameter 46mm. Satin-brushed steel.
Screw-in crown
Dial: black. Numerals, index and hands coveres in a photo-luminescent coating
Glass: anti-reflective sapphire.
Water: resistance: 100m.
Straps: N/A
Buckle: pin buckle. satin-brushed steel.
TECHNICAL SPECIFICATIONS:
File comment: XWidget - Bell & Ross BR 01-97
Bell_And_Ross_-_Version1.zip [924.35 KiB]
Downloaded 779 times
PostPosted: September 24th, 2012, 1:54 am
cool! I like it very much
PostPosted: September 25th, 2012, 12:02 pm
I wanted to make it possible to have the user interact with the widget, and choose whether the indicator should be CPU or Battery, but it seems that you cannot change core on an instrument through user interaction. Anyone has any idea how I might do that?
PostPosted: October 17th, 2012, 11:57 am
My next creation is the BR-01 Altimeter with CPU indicator.
BR 01 ALTIMETER
BR0192-ALTIMETER
The BR 01 ALTIMETER watch is inspired by aircraft cockpits, where each part is a reference in terms of legibility, reliability and performance. The display of the BR 01 ALTIMETER recalls the graphics of the reference instrument the altimeter.
Functions: hours, minutes. Date. CPU indicator
Case: XL Diameter 46mm. Steel with matte black PVD finish. Screw-in crown
Dial: black. Window at 3 o'clock. Hands, index markers and date window covered in a photo luminescent coating
Straps: N/A
Buckle: pin buckle. Steel with matte black PVD finish.
File comment: Xwidget - Bell & Ross BR 01 ALTIMETER
BR_01_Altimeter.zip [316.88 KiB]
Downloaded 817 times
PostPosted: October 17th, 2012, 11:59 am
Example of aircraft altimeter
PostPosted: October 17th, 2012, 12:13 pm
This creation is inspired from the BR-01 COMPASS, but modified with CPU indicator, RAM usage and Network Upload and Download. I matches size and style of the BR-01 ALTIMETER.
BR 01 COMPASS
BR0192-COMPASS
True to the Bell & Ross philosophy, the BR 01 COMPASS watch is inspired by aircraft cockpits, where each part is a reference in terms of legibility, reliability and performance. The display of the BR 01 COMPASS is reminiscent of a navigation compass.
Functions: CPU %, RAM %. Upload Total, Download Total, Upload %, Download %, Clockwise measurement
Dial: disc display: two black concentric discs. Outer upmost ring display CPU and RAM (clockwise measurement) Inner circle Upload% and Download%.
Straps: N/A
File comment: XWidget - BR01 COMPASS
BR_01_Compass.zip [278.05 KiB]
Downloaded 793 times
PostPosted: October 18th, 2012, 10:50 pm
Cool skins! Love the artwork. For the user-selected cores, you could have two text objects, each linked to a different core. Then set one to start not visible, and when a user presses a button, it reverses which one is visible with something like this:
function toggleCores(){
     cpuText.visible = !cpuText.visible //started visible
     battText.visible = !battText.visible //started not visible
deviantArt profile
My Widgets:
Game Specials v1.1
PostPosted: October 23rd, 2012, 12:34 am
Great idea! Thanks. I actually already made the BR 01-97 with two indicators (CPU/Batt), so I guess I just need to hide one at start then switch.
PostPosted: March 16th, 2013, 11:02 pm
I can see I will have to update the next design with the latest Bell&Ross 03-90 Reserve De Marche. Very nice design.
Users browsing this forum: Google [Bot] and 175 guests
