PostPosted: September 14th, 2012, 4:35 am
Download link: http://4ybak47.deviantart.com/art/xWidg ... -324424626
Update 1.1
*flip added
*color is being saved
*UI menu changed
*hint's added
Update 1.1.1
*Auto fill algorithm added.
Update 1.1.2
*Easy to create cotume color set added (Edit the "selectColor1" gradient color and when you lounch the widget -> Click to change the widget color to the gradent color's)
Update 1.1.3
*Major bug fix.
PostPosted: September 14th, 2012, 8:09 am
hi, vlad ,there is no need to make a ChangeColor panle by yourself, you can use SelectColor()
//select color
text1.font.fill.color= SelectColor(rgba(0,0,0,255));
//SelectColor(defaultColor)    if you click 'cancle' on the SelectColor panel, the defaultColor would be used
//setcolor
SetValue('color',text1.font.fill.color);
SaveValue();
//getColor
text1.font.fill.color = GetValue('color',rgba(0,0,0,255));
right click widget → window →package , then you will get a .XWidgetPkg file , everyone can doubleClick it to install your widget :D
PostPosted: September 15th, 2012, 3:02 am
Very powerful widget. I love using it. :D
Users browsing this forum: Google [Bot] and 240 guests
