It is currently October 23rd, 2026, 7:30 am
 Post subject: Turn Off Monitor
PostPosted: September 8th, 2012, 10:45 am
This Widget is a button to turn off the monitor.
MonitorOff.zip [48.67 KiB]
Downloaded 523 times
 Post subject: Re: Turn Off Monitor
PostPosted: September 10th, 2012, 3:40 am
Awesome! I'm using your off.exe in my application. I'll give you the proper credits. The application is called Advanced Panel 3 ™ If you want to check it out.
PostPosted: September 10th, 2012, 4:02 am
No need to wait till the laptop screen dims off by its left, simply smart 8-)
PostPosted: September 20th, 2012, 5:59 pm
Hi, Please Do not Include EXE file in Widget, It is not safe, I had deleted this EXE file and had updated the Attachment.
And the XWidget had include the function of "turn off monitor", not need EXE file to do this.
You just need select the action "!CloseMonitor" in the button OnClick event.
Users browsing this forum: Google [Bot] and 206 guests
