It is currently June 14th, 2025, 7:29 pm
PostPosted: June 14th, 2012, 12:10 am
My first widget.
Apologize for my English, I am Spanish.
This is my first widget, it is a pipe which sends the files placed on top, to the folder you indicate.
The pipe is the super mario bros, configurable in 4 colors, plus you can write in them the name of the folder.
Link
http://depositfiles.com/files/strk113fd
PostPosted: June 14th, 2012, 2:04 am
Nice widget, thanks for sharing :)
PostPosted: June 14th, 2012, 9:07 am
I have a question. in the code, How I can wait for a movement finish and after continue the program ejecution?
thanks.
PostPosted: June 14th, 2012, 9:40 pm
Update the widget.
Now the pipes don`t lost their configuration when restart the program Xwidget.
http://depositfiles.com/files/d7ko7fsh8
PostPosted: June 20th, 2012, 10:37 am
thanks.
//for example print "abc" and wait 1 second ,and then print "123"
function print123()
print("123");
function keyonclick()
print("abc");
settimeout("print123",1000) //1s = 1000ms
facebook:http://www.facebook.com/ZhaoKenneth
weibo:http://weibo.com/102030456
twitter:http://twitter.com/colawings
DeviantArt:http://kenneth117.deviantart.com/
PostPosted: June 21st, 2012, 12:07 am
thanks kenneth112, this is that i was search.
PostPosted: December 22nd, 2012, 1:14 am
Bovedano wrote:
Update the widget.
Thanks for the upload but the link is dead :/ Please re-up
Users browsing this forum: Bing [Bot] and 40 guests
