PostPosted: August 19th, 2012, 6:24 am
Hey! This is my second release, and it's a windows control panel! Easy Windows Control allows you to easily Log Off, Restart or Turn Off your machine! The next version of this will be probably implemented into the Advanced Panel, so make sure you stay tuned!
More information at:
hava.ionut@yahoo.com
Best regards,
Nutu'
Image of Easy Windows Control:
File comment: Easy Windows Control V1.0
Easy Windows Control.rar [64.02 KiB]
Downloaded 450 times
Users browsing this forum: Google [Bot] and 157 guests
