 Post subject: Corner via JAVA
PostPosted: September 17th, 2019, 12:32 pm
Hello, i have a simple question.
How do you use this code to round the corners ?
image1.corner.corners = ??
// ===== Contact ===== //
https://discord.gg/9vyhv3F
// ===== My Widget ===== //
 Post subject: Re: Corner via JAVA
PostPosted: September 17th, 2019, 2:48 pm
Hi Rom. I never used a js code for this.
Personally I always do this way:
1. Or by creating manually corners to an png image using for example GIMP that is pretty easy making high quality images
2. Or using the editor's "Shape" tab and change the "Corner" values - "Style"
Edit: Read below.
I think it's what you want :)
PostPosted: September 17th, 2019, 3:00 pm
Hi Rom,
Try this thread.
viewtopic.php?f=7&t=2103
It has a function to make it easy and a little farther down are the options to use in js. IE:
backboard_small.Corner.Corners =0(disable corner)
                               =1(TopLeft)
                               =2(TopRight)
                               =3(TopLeft + TopRight)
                               =4(BottomLeft)
                               =7(TopLeft + TopRight +BottomLeft)
                               =8(BottomRight)
                               =15(TopLeft + TopRight +BottomLeft + BottomRight)
PostPosted: September 18th, 2019, 3:56 pm
Realy thx !
Its that i need....Thx :) :) :) :)
Users browsing this forum: No registered users and 50 guests
