 Post subject: DLL
PostPosted: June 29th, 2014, 2:37 am
Is it possible to incorporate a DLL inside the widget - or is their documentation for creating your own core?
I'd like to make a widget to view my ebay bids. Ebay has the api's to do this in .net so I figured I could put the functionality in a dll and use it in xWidget but I am not sure it is possible. The docs for making your own core would be great, then other people can use my dll as well.
Villaine
 Post subject: Re: DLL
PostPosted: June 29th, 2014, 10:52 am
Thinking out loud here for anyone's input. I could probably connect to eBay using SOAP in vbscript/javascript. However that connection string contains my developer credentials which I don't want anyone to see. Is it possible to make an uneditable xwidget? or at least one that stops users from seeing the script code?
Villaine
PostPosted: October 15th, 2014, 10:56 am
No
