 Post subject: Main Documentation Link
PostPosted: October 24th, 2013, 5:33 am
Hello all,
I am new to xWidgets. I need to replace VB6 apps and dont want to use .Net or Java. This looks great!
Other than small user snippets in the given BBS forum, where can I find documentation on the language and basics application creation?
Odd that the website does not have a link. Cant find it in the install anywhere either.
Thanks,
Michael
PostPosted: October 26th, 2013, 12:15 pm
Anyone?
PostPosted: October 28th, 2013, 8:19 am
Nope, the documentation isn't ready yet. In this forum you can find some bits scattered though. And a thing to note, XWidget is NOT a application runtime. It is intended to be a widget platform (like windows sidebar). The programming language used is javascript. So if you need to upgrade VB6 apps, better go with .NET
PostPosted: October 28th, 2013, 11:27 am
Thanks for the response digigamer.
Users browsing this forum: No registered users and 50 guests
