It is currently October 23rd, 2026, 1:11 am
PostPosted: May 12th, 2013, 7:42 pm
i would like a list of different details i can give the weather.
PostPosted: March 19th, 2014, 12:16 am
me too
how can i add diffrent image for morning ,noon, evening
need help
PostPosted: March 19th, 2014, 2:02 am
@travis1: i would like a list of different details i can give the weather.
The weather widgets have the right click option "Change Location" or something similar. Click on it and when the "search city" panel appears go back and you will see more weather info + 15days forecast.
@dack23: how can i add diffrent image for morning ,noon, evening
You mean when you create a widget?
I don't know if the developer will add this function for the weather widgets, but for now the accuweather core service not supports hourly weather forecast when you create a widget.
It has "only" current weather conditions + weather up to 15 days and the weather images change for day/night (40 weather icons/images for the wth conditions)
PostPosted: March 19th, 2014, 6:33 am
yes when i create a widget with xwidget designer
where is definied what picture shows
example
8 o clock morning shows image morning.png (but when its cloudy morningcloudy.png or rainy or thunder)
13 o clock morning shows image noon.png (but when its cloudy nooncloudy.png or rainy or thunder)
17 o clock morning shows image afternoon.png (but when its cloudy afternooncloudy.png or rainy or thunder)
20 o clock morning shows image evening.png (but when its cloudy eveningcloudy.png or rainy or thunder)
22 o clock morning shows image night.png (but when its cloudy nightcloudy.png or rainy or thunder)
thanks for help
anf how can i change the language of months and days?
PostPosted: March 19th, 2014, 8:35 am
example
thanks for help
I don't know if can this be applied for the weather images but check this post:
viewtopic.php?f=8&t=2911
The sure is that needs a particular script code for this!
(or you need to wait an answer from who knows script better than me)
I can tell you that there are two modes/tags for the weather icons/images:
1) ${curWeatherIconNum}.png that needs 40 images for the weather conditions
2) ${curSimpleWeatherIcon}.png that needs 8 images for the weather conditions
sun, cloudy, fog, rain, lightning, snow, moon, moon_cloudy
For the language, in general there are two kind of tags, normal and with the "En" inside. With the second one all the txt will be in English and with the first the txt will follow the language of your system. There are some tags though that support only english.
(that's why in my widget I always select English for all the txts)
PostPosted: March 22nd, 2014, 5:21 am
but what i need to do to get this images work
in which file it is definied when will which image loading
PostPosted: March 22nd, 2014, 5:36 am
As I told you using the ${curSimpleWeatherIcon}.png tag you need 8 images for the weather conditions
but the default tags (I don't know for the next release/s) not support day/night function.
(the fog image for example will be the same for and day and night)
You need a particular script code for this.
Check the link in my prev post to see if this can help you..
BUT using the other tag ${curWeatherIconNum}.png that need 40 images you can have day and night images!
Download a weather widget posted here, edit and check it from the inside.
This for example:
viewtopic.php?f=11&t=4266
Also check this:
viewtopic.php?f=3&t=2689
PostPosted: March 22nd, 2014, 5:44 am
sorry for the stupid questions thanx a lot for ur help u are awesome
PostPosted: March 22nd, 2014, 5:52 am
You're welcome! :)
Users browsing this forum: No registered users and 49 guests
